SP1000 with blank copies after new toner
  • mrwho
    Major Asshole!
    • 4299
    [CQ] SP1000 with blank copies after new toner
    Good morning.
    We got this description from a customer via phone caliming that after putting in a new toner and inserting the card that came with it, the machine only spits out white copies.
    He didn't buy the toner from us, though, so we can't say for sure if the toner is OEM, but we're assuming it is since the customer says so (and until we go there and check for ourselves).
    Any tips?
    Thanks!
    Mascan42
    Ibid
  • PinevskiS
    • Jul 2009
    • 284
    Hi
    i have this problem with this machine and with ather machin how have this toner.problem is a toner ,on charge roller have to mutch fat . You must open toner and c lin the fat everywhere on contacts.this toner is ok but you must clin the fat.
    Bay.
    • PinevskiS
      • Jul 2009
      • 284
      Originally posted by PinevskiS
      Hi
      Bay.
      Belief me
      • mrwho
        Major Asshole!
        • 4299
        Sorry for the delay.
        Thank you for your input, but the machine still has the same problem with a different imaging unit.
        We got the machine brought into the shop, so we still don't know what's wrong - but it's most probably going to need parts.
        Check this post here.
        Mascan42
        Ibid
        • zyqwiz
          • Jun 2009
          • 333
          These machines are Samsungs. Buy a new one and give it to the customer - the warranty should never be longer than the Ricoh 1st year one and make sure the customer fills out the warranty card so you don't have to even go and look at them!
          • mrwho
            Major Asshole!
            • 4299
            Still don't know what's the problem with this POS. Replaced the main PCB, the PSU and the laser from a working machine, and dismantled the damned thing to check the connectors - still the same. I don't know what else to do - I'm going to browse the service manual to look for any clues.
            Mascan42
            Ibid
            • mrwho
              Major Asshole!
              • 4299
              Just ruled out the HV assembly. Managed to point a flashlight onto the drum while the machine was printing and it made a nice black band on the paper.
              Now either the laser is not working (not likely, since I tried with a laser from another machine), the mainboard is defective (also not likely for the same reason) or there's something wrong with the laser path (which I can't find, since everything seems to be in place).
              Now if only I could find that hammer...
              Mascan42
              Ibid
              • Vulkor
                • Jun 2009
                • 942
                How many hours in invested in this thing? We don't warrant any work if off brand supplies or labor has been done to it.
                • mrwho
                  Major Asshole!
                  • 4299
                  As for third-party supplies or labor, everything seems to be in order, there's no evidence of either one on the machine.
                  I've spent already some hours on this thing, as well as my colleague. Our luck is that, at this time of year, work slows down, and thus we have some spare time to spend on lemons like this one.
                  Mascan42
                  Ibid
                  • teebee1234
                    • Jul 2008
                    • 1670
                    Did you check the shutter that blocks the laser beam path when the front door is open? The customer may have broken the tab on the front door that pushes in the shutter (that's part of the laser unit, it's actually a tab that pushes into the laser assembly and blocks the beam).
                    • mrwho
                      Major Asshole!
                      • 4299
                      Thanks, yes, I've checked that while still at the customer's. If that was the case, the machine would return an HSYNC error (as it did when I tried to block it - it at least confirmed that the laser diode is emiting).
                      Cheers!
                      Mascan42
                      Ibid
                      • mrwho
                        Major Asshole!
                        • 4299
                        I managed to finally SEE the laser working and found out that the laser beam stays put at the end of the drum during the entire copy cycle except for the end of the job, where it sweeps the entire drum to clean the leftover charge. Trouble is it does it with two different laser assemblies and two different control boards.
                        So what's left? That's right, we need to try with a different touch panel assembly (maybe it has something broken that triggers this symptom).
                        Mascan42
                        Ibid
                        • Polo-022
                          • Sep 2007
                          • 481
                          O.k! Copies blank,..what about internal prints????
                          I would check optical path and scanning procedure...did you?
                          • mrwho
                            Major Asshole!
                            • 4299
                            Sorry, my bad I didn't make it clear before - the machine does this trouble while copying and printing internal prints. Although I mentioned printing in one of the posts, I didn't emphasize it. Thanks for the tip, though - every help counts.
                            Mascan42
                            Ibid
                            • mrwho
                              Major Asshole!
                              • 4299
                              This POS is driving me mad. Of course at this time it would be simpler to just swap the effing thing, but my boss wants to know what happened - and, to be honest, I want too.
                              I decided to take a video from the laser working to share with you. In it you can see the laser doing an initial sweep to the entire drum, then the beam stays put at the right side during the entire copy process and, at the end, it does a final sweep. Pay no attention to the paper coming out with a black stripe - it's caused by the ambient light hiting the drum.
                              We already swapped virtually everything on the machine: PSU, Control Board, Laser unit and Operation panel. I've even taken out the door switch and shunted the wires to rule it out.
                              Mascan42
                              Ibid
