icoh 1022
  • tulipano
    • May 2010
    • 124
    icoh 1022
    salve vi e ' mai capitato che in una ricoh 1022 quando fotocopia o stampa fa un rumore tipo tac tac tac tac atc me lo fa su tutte questi modelli.
    da cosa puo' dipendere
  • Vulkor
    • Jun 2009
    • 946
    prejudice there 'ever in 1022 when a ricoh photocopy or print makes a noise like tac tac tac tac atc makes me all these models.
    What can be the cause?
    FUSER BEARING or Cracked Lower Fuser Frame. Flat/Worn side of Pressure Roller. Overworn Fuser Cleaning roller.
    • jonhiker
      • 661
      I have found that most of the time, in this modelm, it is the pressure roller bearing. i usally go ahead and do a complete rebuild.
      • Vulkor
        • Jun 2009
        • 946
        Yep, same here, Thermistors, PR, HT, Cleaning Roller, HR and PR Bearings. Sometimes the gear. Sometimes when you pull out the HR you will see the frame nearest the gear cracked or broken.
        • DCW98
          • Jun 2010
          • 11
          Roughen the surface of the hotroller where the bearing come (use something like a big plier to scratch).
          Then use a bit (just a bit is enough) of heat grease and mount the bearing. They might be tapped on.
          If you just mount new bearings, noise will be back in no time .....
          Good luck !!!
