c548 error code
  • docpc2
    • Jul 2025
    [Error Code] c548 error code
    trying to find the most common cause of this code and how to resolve it
  • tcs04
    FORMER Techie
    • 1183
    Depends on the machine....................
    • docpc2
      thought I documented model savin c3535/aficio mpc3500
      • Jomama46
        • 2900
        For me, most of the time its a dirty sensor. Lots of crud in that area. Could also be the motor isn't turning or the actuator is bent.
        sigpic
        A+; Network +; PDI+
        • sakura
          • 132
          The most possible cause of SC548 on those models you mentioned are thermistors/fuses. Overtime dirt (paper dust mixed with a toner) start covering temperature sensors and one day it gets so bad that sensors can not measure it properly. It causes SC 548/542/555 etc. Replace all of the fuer thermistors first. Also check all thermo fuses (they come as 1 unit) for any dirt buildups. I would also recommend to replace fusing unit cleaning roller+lub roller if they are noticeably worn out and lub.roller has flat spots on it (very common problem on MPC3500 type of machines). Hope it helps.
          • paulg
            • Jun 2007
            • 278
            Although it was in a very early firmware release make sure the firmware is updated as a customer not putting the fusing unit back in correctly a couple of times could set off SC 548 which meant a Engineer had to go to reset. But if the Firmware is ok then what the other guys say.
            • Jomama46
              • 2900
              SC548: Fusing unit rotation error. “A”
              The fusing belt sensor does not detect change in the actuator for 0.5 seconds after the fusing/paper exit motor has turned on.
              Replace the fusing belt sensor or actuator; replace the IH inverter; IOB
              sigpic
              A+; Network +; PDI+
              • jonhiker
                • 661
                there is a sensor on the operator side of the machine(your left) that is a home position sensor for the fusing belt. i have seen it knocked out of position and that will generate this code.
                • Eric1968
                  • 2458
                  I'm with Jomama46. Saw this SC a few months ago. A lot of dirt near the belt sensor. Cleaned it and until now it runs OK.
                  • kyoceran
                    • 100
                    had a couple of clean thermistors go faulty , easy to replace, less chance of return.
                    • CableGuy
                      Impulse Drive Engineer
                      • Oct 2008
                      • 417
                      Does this machine have a finisher on it?
