Line on duplex mpc 3500
  • sebreizh
    • Oct 2009
    • 28
    I have a problem on an MPC 3500. when I want to make a one duplex, a line appears on the first sheet. I try on the ADF and on the window, is a same problem. I think the problem comes from printing the first page. I will wish to shift sp mode only the first page on the right.
    Thanks.
  • Jomama46
    • 2900
    User tools>copy setting> edit>duplex margin , set to 0
    sigpic
    A+; Network +; PDI+
    • zed255
      How'd ya manage that?
      • 1024
      I agree with Jomama46. The duplex margins are set to 0.2 inch by default and cause the edge of the page to be copied. I check these as a matter of course on most machines I see for the first time in the field.
      • Vulkor
        • Jun 2009
        • 946
        Yeah we always set to 0.0 in shop before delivery.
        • tcs04
          FORMER Techie
          • 1183
          Check by copying from the glass in " 2 sided / 2 sided" mode. If the line goes away it.'s the margin adjust.
          • rednecktech
            • 54
            Yep, nailed it.
