ID 2 @Remote
  • Philinghorn
    • Sep 2008
    • 29
    ID 2 @Remote
    Hello,
    Any @Remote wizards out there ?
    We have a machine where we have had to replace the NVRAM, all os OK apart from the ID2, its not the correct format. Does anybody know if & how we change the ID2 back to what is should be ?
    This machine is using the embedded version of @Remote & its a MPC4500 if it makes a difference.
    Thanks inadvance for any replies.
  • Ricoh-ono
    • 338
    If only NVRAM is replaced then input original serial in SP5811-001.
    If NVRAM and controller replaced then input original serial in SP5811-001. You will also need to restore individual certificate with Rescue mode by initializing SP5870-003.
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
    • Philinghorn
      • Sep 2008
      • 29
      Thank you Ricoh-ono.
