DSm660 "Please Wait"
  • 3bok3bok68
    Senior MFP Technician
    • Nov 2008
    • 56
    I have a nashuatec DSm660 showing in the display panel "please wait" eventhough I replaced a new HDD...anyone can experience this? please share to me....thanks in advance...
  • TonerMunkeh
    Professional Moron
    • 3865
    Try disconnecting all the options and starting the machine with the door open and the fuser out. If it starts, reconnect all the options one by one until it does it again.
    Hit it.
    • 3bok3bok68
      • Nov 2008
      • 56
      Thank you so much TonerMunkeh....I will try what you advise to me...god bless.
      • mikadonovan
        • May 2008
        • 2931
        I had this happen to me before on this model. The screws had come loose on the metal plate attatched to the machine frame that has the set pins for the front of the fusing unit. After realignment and tightening the problem was solved.
        NEVER ASSUME ANYTHING
        • 3bok3bok68
          • Nov 2008
          • 56
          thanks so much mikadonovan....
          • shlo1
            • Jul 2010
            • 9
            it is a drum problem the vsp vsg wrong.
            • slot
              • Jul 2008
              • 341
              I have had this when the web has run to the end and on several machines it has been the memory
              i have had one time when the fuser controle had been changed and this dragged the machine down with please wait also check the thermistors
