2238C Constant SC-388 SC-389
  • tinfox
    • 317
    This machine had been unlevel because the floor is sagging(higher in back than front) so at first I figured it threw off the toner sensors or something.
    So I rolled into another room where it would be level and did a PM on it. I put in all new devs and drums.
    After doing the PM I couldn't get the machine to complete an "Auto Color Calibration" without throwing one of those codes.
    Not knowing what else to do and since it was making nice prints/copies I rolled it back in to the room and let them use it.
    This was about 5 months ago. Now about a month ago the 1 month ago it started throwing the codes again and the CYAN and the MAGENTA devs are overtoned.
    I put in a known good transfer asm just to see if it was that. Also I bent the retaining bar in a bit to make sure the devs where tight.
    I have a new CYAN and MAGENTA dev to throw in there, but i just don't want to keep doing that every three months. Its a non-profit and I'm trying to help them out. 'Cuz that's just the kinda guy I am.
    TIA
    tin
  • Screw Turner
    • Feb 2010
    • 11
    Copy & Paste from svc man. hope it helps...
    • Unsuitable toner
    density
    • Toner supply
    mechanism problem
    • Laser exposure
    problem
    • Image transfer
    problem
    1. Turn the main switch off and on .
    2. Check the process control self-check
    result (SP3-975). If the result is not
    “1”, fix the problem according to the
    table in section 4.1.2.
    3. Print a full color image by disabling
    SC detection (SP5-809-001) and
    check if the image quality is OK. If the
    image quality is not OK, fix the
    problem. Then, enable the SC
    detection again.
    • Eric1968
      • 2459
      When the development clutches aren't working correctly, you can also get these messages. I would not recommend bending the bars, because if the distance between the drums and dv-units is wrong, you can get a lot of strange SC's.
      • tinfox
        • 317
        I checked (SP3-975) and I got 1555 at first. Then I replaced and initialized both CYAN and MEGENTA, after it tried to go thru "color calibation" I got SC-387. So I rebooted the machine and checked (SP3-975) again and got 1666. I ran a test copy and noticed there was streaking in the middle on thh back off the copy.
        I'm going to go out tomorrow with a trasnfer belt cleaning blade. Maybe that will fix it. I'll psot back then...
        • Eric1968
          • 2459
          If the belt is over 250k, I would replace it too.
          • tinfox
            • 317
            Well I just put on a new transfer belt and blade and still can't get through auto color calibration.
            I just checked SP3-975 and now I'm getting 5111 which i guess is an improvement. The black is grayed out on a test print. Something must have gotten whacked.
            I'll post back later. I'm going back to the customers office.
            Later that day...
            So I brought the transfer unit with the new belt and blade back to the office and and it worked fine. So I drove out to the customers office again........ and of course it worked fine. %@#%SDFW#%W#%3w
            Anywho, I was finally able to run "Auto Color Calibration"! Yea!
            Thanks to all. The clue that it was the transfer unit was the 1555 and 1666.
