Hi, i work on Ricoh Fax Aficio 5510L with alram code 0550, can someone show me how to reset it . thanks.
Ricoh Fax Aficio 5510 L
SC550 -The fusing temperature fails to drop down to the standby
temperature within a specified period of time.
fyi- You will probably need to replace the fuser unit before resetting the code.
To reset, go into the Service Mode
- User Tools>#>1>0>7>Start Key
- Select 01 (Bit Switch)
- Select 2 (Plotter) *Plotter and Printer are the same*
- Set printer switch 01 bit 0 to 1 and turn the power
off and on.
