Savin 816 ADF Pulling Whole Stacks
  • Vulkor
    • Jun 2009
    • 942
    These ADF's for these 816s are killing us with our customers. They continuously double feed. We've done Bulletin 007R for the Spring Plate on all the ADF's. Some multiple times. We've replaced whole original feed units which include a Oneway Clutch (one on end), Roller Clutch:Bracket:Feed, Feed Roller and Pickup Roller. We've replaced the Separation Rollers, the bracket the Reverse Roller sits in. The Stepper Motor on the back, the feed clutch on the front.
    Seriously this is aggravating.
  • Fearless V K
    • 620
    You need to tweak the separation pressure by bending the spring plate until you find the 'sweet spot'.
    Don't take that toner with me!
    • Vulkor
      • Jun 2009
      • 942
      Yeah that is what I was figuring. Absolutely bullsh*t design from Ricoh. We are getting so tired of there machines the dealership is considering switching brands.
      • Vulkor
        • Jun 2009
        • 942
        Just wanted to say DIE 816 ADF!
        • Jomama46
          • 2900
          The new spring is B872-2251 and can be identified as having 2 small holes.
          sigpic
          A+; Network +; PDI+
          • Vulkor
            • Jun 2009
            • 942
            Savin is Retarded. The Bulletin Says B872-2251, The parts Catalog says B872 2212. I swear to all that is unholy I'm finding a job with a different copier company.
            • Jomama46
              • 2900
              Vulkor you need a drink, badly!
              Aside from that, 2212 is the old number and 2251 is the modified spring. It is strange that you are having so much problem with this line. We have a shxtload of this series out from 1302 to 171 and service is rare.
              I have other machines that make me drink tho.
              sigpic
              A+; Network +; PDI+
              • Jimbo1
                • Mar 2008
                • 845
                Two words -- Kyocera Mita--. Much less aggravating..
                "Some days you get the bear, some days the bear gets you."
                Cdr. William Riker
                • Vulkor
                  • Jun 2009
                  • 942
                  Aside from that, 2212 is the old number and 2251 is the modified spring. It is strange that you are having so much problem with this line. We have a shitload of this series out from 1302 to 171 and service is rare.
                  We must have over 30 of the 816/Ricoh 161/Ricoh 171. Well only 2-3 of the Ricoh 171. No problem from them much except for crooked copies out of the box. But I think we currently have maybe 15 with ADF issues. They just pull multiple sheets. We've replaced with the new spring plate. I checked our stock and we do have the new number. They substitute the old # for the new when we order. We've replaced entire feed assembly. That is the one way's, pickup, feed, sep roller. The carriage that holds the Sep roller, DF Feed Motor and DF Feed Clutch. No way we have over a dozen with Bad Boards.
                  Only other serious problem machines we have are Savin 8035e/9040/9050 Any that use the New E toner. Their PM's NEVER last to PM cycle. If you get 100k of good copies that is the lottery.
                  • Vulkor
                    • Jun 2009
                    • 942
                    Thought Kyocera was a different company than Mita. So ticked off I got a Job App Form for a Kyrocera/Canon Dealer and a Sharp Dealer in front of me filling them out. Tired of poor design and poor budget for repair on machines. BubbleGum and Superglue only work for so long.
                    • Fearless V K
                      • 620
                      Just remember when you start putting bubblegum and superglue on the sharps, canons and kyoceras also, that no one has ever built the perfect machine. if they had. none of us would be working!
                      • Vulkor
                        • Jun 2009
                        • 942
                        Yeah I am sure that will occur. But If quality is indicated by how many people ask for help on these forums. Well the Ricoh line has some issues. See below
                        Canon
                        • Threads: 120
                        Konica Minolta
                        • Threads: 5,280
                        Kyocera Mita, Copystar
                        • Threads: 1,288
                        Muratec
                        • Threads: 48
                        Panasonic
                        • Threads: 339
                        Ricoh, Savin
                        • Threads: 4,231
                        etc... Gotta say Those Konica Minoltas sure have a lot of questions. Of course the amount of post could also indicate popularity or something else.
                        • ucinn
                          • Jun 2009
                          • 383
                          Population has a lot to do with it. Our dealership, we do Canon, Minolta, HP, and Lanier. Out of those machines, the Laniers are by far better deigned and easier to work on.
