I have a machine thats throwing a Sc 555 error and I cant find that one in the service manual. What may that be?
Ricoh Aficio 2075 error
You never realize how cheap a professional is until after you let an amateur do it....and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!! -
Thermistors / thermostats. Replace them.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
thanks!You never realize how cheap a professional is until after you let an amateur do it....and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!Comment
Believe it or not, you can restore continuity through the thermostat by smacking it on a hard surface. First time I heard this I thought it was a load of crap, but I've tried it, and it works.NEVER ASSUME ANYTHINGComment
Spraying them with the sort of deodorant that sprays really cold works too, randomly enough.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Hit it.Comment
no kidding and some of the customers are even worse. whoooooYou never realize how cheap a professional is until after you let an amateur do it....and
Maybe not by SC code description, but I have found failed thermofuses will sometimes cause this code.NEVER ASSUME ANYTHINGComment
Dont try to reset thermostats by smacking them on the back, the reeds can hop over one another and never pop again, therefore making them a much bigger problem, like fire!!. I replace all thermistors and therostats on any Ricoh fuser at PM. Seems to be solving alot of problems in this cold wintery weather.I have not failed. I've just found 10,000 ways that won't work. ~Thomas EdisonComment
farzin58j
HI
I'M FARZIN FROM IRAN
I need the error codes ricoh 2075
Can someone give me the codes?
Thank you very muchComment
