Hi All,
I have a fairly new 907 ( 400k ) that gives fairly regular J015 ( T6 transport late ) and J021 ( cooling pip late ) codes. The J015 codes are from T6 on a 5030 LCIT. It seems as if it is trying to feed multiple sheets of paper at once. So far I have changed T6: feed and separation rollers, torque limiter and have done the double feed lift sensor adj. On the J021 code I have lubed the fuser drive coupling, cleaned all the one way roller bearings and replaced the fuser exit sensor. Still have intermittent jams. Can anyone suggest anything else for me to try? TIA
