Lanier LD232c not printing colour correctly blurred
  • andrew1986uk
    • Aug 2025
    [Misc] Lanier LD232c not printing colour correctly blurred
    The works photocopier is not printing colour correctly, the black is fine, but colour prints are blurred and almost look like a 3d image.lol if you get me drift, any ideas please share chaps.
    • 23009
    It would help if you attached a scan of the problem.
    Perhaps you have a color registration problem? =^..^=
    • RRodgers
      • Jun 2009
      • 1947
      What he said.
      turn it off and let is sit for at least an hour or two, then fire it back up and see if the problem goes away. If not, you are going to need to clean the sensors that are right above the transfer belt. (up on the top left)
      • rthonpm
        • Aug 2007
        • 2859
        Clean the ID sensors and replace the registration roller.
        • teebee1234
          • Jul 2008
          • 1670
          Here's an adjustment bulletin to try if all else fails (clean music sensors, replace transfer belt and clean the silver roller under the transfer belt that the sensors face).
          • andrew1986uk
            thanks guys, i'm i right in thinking transfer belt is underneath the colour toner carts, along with the sensors.
            • teebee1234
              • Jul 2008
              • 1670
              The sensor assy is mounted on the inside frame in the upper left corner. Once you remove the transfer unit (yes, under the pcu/dev units) and the black pcu and black dev unit (you might want to remove all the units for cleaning and a better visual) you will be able to access it. There is a spring loaded shutter with windows that covers the sensors. Just push in from the front (silver metal plate sticking out the front area, the front door contacts it when closed) and wipe the sensor faces with a cloth dipped in alcohol.
              • delosangeles
                • May 2008
                • 274
                Q tip
                Teebee is correct. I like to use a Q tip dipped in alcohol.
                Trade like a tiger sleep like a baby
