Ricoh 3228C - cassette #4 motor keeps running after a copy
  • Dexor
    • 223
    Cassette #4 motor never stops after making a copy - it just keeps working. There is no error code, copy exits fine.
    The only way to stop it is to open lower right door. Motor is rather hot.
    Is this likely by faulty firmware or bad board?
    • 22999
    I know this sounds counter-intuitive, but I'd check all the paper switches in SP mode, especially the ones closest to the exit. I'm anticipating that you'll see one switch that stays on steady, or at least is very close to the trigger voltage (flickering On when no paper is present). It wasn't on a Ricoh, but I have seen something similar. =^..^=
    • Dexor
      • 223
      Hmm, I've actually blown some air on the exit switch after it leaves the cassette #4; all other cassettes are fine, they don't cause this problem. If this is a switch, error code is very likely, if not a must. But if anything simple can cause this, I'll give it a shot next time going over all switches.
      • nmfaxman
        • 1702
        Swap feed and sep rollers from another drawer.
        A worn sep roller will cause DSF that actuates the feed in sensor making the motor want to keep driving.
