AF3260 SC445
  • Moza
    • 232
    AF3260 SC445
    Evening all,
    Has anyone had this problem before SC445 (Transfer motor error) also the machine logs SC499 (Transfer belt encoder error) ?
    The error only occurs first thing in the morning then will eventually reset after about an hour or two and run for the rest of the day !
    Have replaced Transfer belt, blade, brush and also PTR, brush, blade etc ...
  • teebee1234
    • Jul 2008
    • 1670
    Is the belt facing the right way (reflective strip going over the sensors) and the belt sensors cleaned? Do you have another ITB unit you can swap out? I would guess the problem is with the belt sensor board.
