I place one a4 originals on glass and select tray2 (contain paper a4) enter 999 using number keys and press start
Two mode is possible if I stop copies job and resume remaining , I want to stop for example from 200 copies , and place one a5 original on glass and select tray1 (contain a5 paper) and enter 5 copy and press start then complete this temporary job , resume first job that is remaining of 999 copies. Refer to manual of 2035 copy reference .
This solution is found but I couldnot to use this solution ,
Interrupt Copy
Use this function if you want to interrupt
a long copy job to make urgently
needed copies.
Limitation
❒ You cannot use the Interrupt Copy
function when fax originals are being
scanned or the scanner function
is being used.
Press the {Interrupt} key.
The Interrupt indicator goes on.
When the originals stop scanning
ARemove the originals that were
being copied and place the
originals you want to copy.
Press the {Start} key.
The machine starts making the
copies.
When copying is complete, remove
the originals and copies.
Press the {Interrupt} key again.
The Interrupt indicator goes off.
EWhen the display prompts
you, place the remaining originals
again before interrupting.
Note
❒ The interrupt copy job settings
will be restored and the
machine will continue copying
from where it left off.
When the machine keeps copying
Place the originals you want to
copy.
The machine stops the previous
original job and starts copying
the original.
will be restored and the machine
Job Preset
You can set up the next copy content
during copying.
If a long copy job is in progress and
you do not want to wait for it to finish,
you can use this function to set up
the next copy job in advance. When
the current copy job is finished, the
next job will start automatically.
Press [Next Job] when "Copying" is
shown.
Set up the next copy job.
Place the originals in the ADF,
and then press the {Start} key.
Press [To "Printing"].
Returns to the initial copy display.
After the current copy job, the next
job starts automatically
othe solution is holding C button more than 10 second , the coping job is stop and appearing on the display continue and stop , press stop , place temporary original on glass and start this job and continue the first job
if you know the correct solution please write for others and me .
thank you for attempt
Interrupt Copy
needed copies.
Limitation
is being used.
copies.
Note
copy.
the original.
Job Preset
during copying.
shown.
