Hi,
i have a problem with machine mp6000 Adf. paper jam suddenly when copy are done.
i check the stepper motor & gears,sensors its ok. i check the stopper shaft separation, i removed it. i do copy, it function correctly. Pls, i have removed the stopper shaft separation are there a problem when i removed it. what are the utility of the stopper shaft separation.
Thanks.
Thanks.
