CL7000 reset fuser unit Correctly
+ More Options
Posts
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    #16
    Originally posted by mrwho
    But why grease it? Isn't it supposed to be a punishment? The only way I'd have it greased was only if I would dip it on fine sand afterwards.
    Even better!!
    • Voltage
      • Jul 2008
      • 282
      #17
      And once it is in, heat the end that is sticking out up so he can not pull it out
      • dgressy
        • Dec 2011
        • 25
        #18
        Re: CL7000 reset fuser unit Correctly
        Hello guys, hello voltage,
        nice to be a part of your site. i hope to help others with my years of experiences in the print industry. I'm master of print technology and an expert in finding the right technology for the printing job.
        different to analog printer it's sometimes hard to find i logic solution inside the rom of a digital printer ...
        in this case it takes me to you.
        after getting no A5 prints out of the second paper tray, i was stupid enough to make the wrong and only one reset of this cl7000 which should not be done. so now i have the same output in the display and i cant even access the web interface configuration pages. the original password didn't work any more; only japan and english language is choose able and the machine wont start printing.
        are you sure that there is no other way of getting back the european settings a.s.o. after the nc reset without changing the controller board? by the way, why and for what operation should this switch in the service menu necessary?
        ... and if so did you only change the controller board without additional adjustments?
        thank you so far &
        with best regards
        gressy
        • katash
          • May 2010
          • 221
          #19
          Originally posted by Jomama46
          I see G0805601. I use a USA firmware site. Maybe Tessa is different.
          I dont have one of those around any more so I cant tell about the destination code.
          this is tessa too
          • dgressy
            • Dec 2011
            • 25
            #20
            thank you, but of course i have no access to it ....
            but in this case - the nc reset change only the nv-ram right? so in new ic nv-ram should fix it?
            • mrwho
              Major Asshole!
              • 4299
              #21
              A new nvram would be completely clear, so no, it wouldn't fix it.
              Mascan42
              Ibid
              • dgressy
                • Dec 2011
                • 25
                #22
                I mean a new programmed IC
                or e.g. from another cl7000?
                • Jomama46
                  • 2900
                  #23
                  That wont work, it would code out right away with a mismatched serial number.
                  sigpic
                  A+; Network +; PDI+
                  • dgressy
                    • Dec 2011
                    • 25
                    #24
                    Interesting!
                    So how whould you make it? It sounds so that you know the procedure?!
                    The hole controller board send to ricoh and they'll programm it new?
                    If so how will they do that. Is it possible to flash the ic via internet?
                    thanks a lot!
                    • Jomama46
                      • 2900
                      #25
                      Ricoh doesn't repair boards anymore, at least on this side of the pond. If you can find an authorized repair center they can do it for you. i.e Hytec Board Repair in Florida.
                      sigpic
                      A+; Network +; PDI+
                      • dgressy
                        • Dec 2011
                        • 25
                        #26
                        Originally posted by Voltage
                        I was running out of time so i just replaced the controller board and bob was my auntie.
                        So - of course it prints but ...
                        How was the registration of the four colors after the replacement? I thought all laser units comes with individual parameters from the manufacture which were written in the board.
                        Or did you have a backup from all these parameters and put in all the adjustments in the machine again?
                        If not it sounds for me that you are maybe lucky that it prints marvelous.
                        Thank you for further information!
