Hi, I have been working on this problem and I'm about to do a full pm dev unit, drum and blade. I saw some discussion about an ID sensor and a drum ground plate, I was wondering where they are located? Are they both located on the drum unit?
mp 4000 sc-304 code
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
Paul@justmanuals.com -
Try this
Here is what the manual says about SC304
Charge roller bias correction leak
The charge roller bias correction is performed twice even if the maximum charge roller bias (-2000V) is applied to the roller.
��ID sensor defective
��Worn charge roller
�� Charge roller damaged
Trade like a tiger sleep like a babyComment
i cant find it now but i beleive there was a bulletin or an improvent to the pcu units to stop this.Comment
you're right silver..,u need to replace the dev unit but to tackle the problem immediatly you need to clean the mag. roller and the pcu recycling pathway.
replace the developer and do the following settings,
sp 2201-01 (dev bias)550-660
sp 2201-02 (dev bias for i.d sensor pattern)400-500
gud luckComment
Pull the drum unit and look in the cavity towards the backplate of the machine, look to the left of the drum drive shaft, you wil see a hole, then to the left of that, the charge contact spring. Is the spring pushed into the recepatcle? If so, using small pliers, pull the end of the spring towards you. This will ensure good charge contact and may help prevent the code. I must say that I had another tech call me today with the background problem and my fix didn't work! His dev unit was almost seized and he ordered a replacement.Comment
Great
Great info
Katash and tcs04 thanks for keying in with that. I will remember your tips for later.Trade like a tiger sleep like a babyComment
