Ricoh Aficio MPC3500
  • toshiba
    • Dec 2006
    • 58
    In ricoh mpc3500 fax option, international faxes are not received. m/c starts handshaking and getting disconnected without any errors. this was working before. i tried with different modem speed settings, different file type settings and different country code settings. but nothing worked out. suggestions please.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Alot of time it turns out to be a problem with the other fax machine or the noise / condition of the line.
    Can you send from the MPC3500 to this other fax machine in question without a TX error?
    Can you send and recieve to different international fax/number from the MPC3500?
    Can you send and recieve to your own office fax machine from the MPC3500?
    Try testing a smaller fax machine plugged into the same line to see if you can dupicate the problem.
    Basically it's a case of general investigation.
    • toshiba
      • Dec 2006
      • 58
      thanx friend.
      i tried the fax with diffrent number in the same country, its a diffrent district. and all locl faxes are receiving and sending. internationational transmission also happening well. i'll try tocheck with diferent country fax now.
      • rthonpm
        • Aug 2007
        • 2858
        Have you tried disabling the ECM? I've found a lot of fax issues can be resolved by turning this off.
