Intermittent print jobs fail to print. Replaced print controller, rebuilt print driver on Server 2003 with latest driver. When prints fail, the server status shows the MFP is off line, yet the I can ping the MFP and open the WIM. This MFP has an Equitrac unit for print/copy cost recovery. Thoughts?
MP7500 Printer "Off Line"
Wade
Server 2003 has had some problems with SNMP enabled printers. On basic setups I have disabled SNMP in the port settings or Microsoft has released a hotfix for it The print queue status is displayed as "Offline" on a Windows Server 2003-based print server if SNMP is enabled and if the printer devices do not respond to SNMP commandsComment
SNMP is required for electronic meter services like @Remote or FMAudit (which my company uses). SNMP is fine. This company has 12 other MFPs and 10 printers from us with SNMP enabled... no problems. Thanks for playing!I'm trying to think, but nothing happens...Comment
Mmmmmm... I may have a similar issue, customer complained of MPC7500 dropping some jobs, data light flashes on machine, then job "disappears" according to customer. This is one of a pair of machines with adjacent I.P details, running with Equitrac. The customer also has various other Ricoh machines running in the same cofiguration, seemingly with no problems. I've not seen the fault happen.Comment
They're all setup for printing with the PCL6 driver and haven't reported any problems.
Which print driver are you using?Comment
Sometimes 'see an error on Ricoh printers that causes the devices to incorrectly report an offline condition after the printer operator has pressed 'job reset' on the printer.Comment
Roadking did you ever figure out what was causing it to go offline?
I had a similar issue on an MPc5000 w/ W2k SP2 and tried unchecking SNMP to no avail. I also tried changing to the PCL5 driver, etc.
I replaced the controller and it quit going offline.
The reason I ask is because when I first Googled it, there were multiple hits on W2k causing printers to go offline.
