Pretty sure there is a bulletin on this, keeps reoccurring. Also what is the proper position for the thermistors? There is no mention of it in the book, i am not trained on this machine.
Ricoh mp6001/savin 9060 sc555
Also the fuser drawer may be losing contact. put a 2mm washer on the screws that hold the fuser connector on. Use them to shim the connector towards the rear.sigpic
A+; Network +; PDI+Comment
replace the new type thermistor and bracket
D0624197BRACKET:THERMISTOR:MIDDLED0624196BRACKET:THERMISTOR:INNER BACKAW100131 THERMISTOR:FUSING:MIDDLE
AW100132THERMISTOR:FUSING:INNERBACK
