Ricoh AF 2045
  • hafeez a latif
    • Aug 2025
    [Error Code] Ricoh AF 2045
    Hi i have a problem in ricoh af 2045 Code sc990 plz help me out form it .
  • Eric1968
    • 2458
    Update Engine and Controller firmware.
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      It can be the drum, over its limits.
      • jonhiker
        • 661
        990 B Software performance error
        The software attempted to perform an unexpected operation.
        Software defective
        Internal parameter incorrect
        Insufficient working memory
        When this SC occurs, the file name,address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
        991 D Software continuity error
        The software attempted to perform and unexpected operation. However, unlike
        SC990, the object of the error is continuity of the software.
        Software bug
        These codes are Ricoh's way of saying"Generic Software Error". I agree with Eric and update the firmware.
        • nmfaxman
          • 1702
          Drum worn or charge roller contacts dirty-not making good contact.
          Most common for this machine.
          • rsyarcia
            Hair Straightener Tech
            • 711
            i agree! we encountered that many times.
            Nobody is perfect..
            • pfinn10
              • Jun 2010
              • 46
              Make sure firmware is up to date, and replace PCU
