Ricoh 3045
  • edgareddy
    • Jan 2007
    • 11
    Ricoh 3045
    I have a problem on this machine, The SP modes screen is in Chinese. I also have SC code 548 and door open indicator as soon as I turn it on
    • 23006
    Logic errors
    The SC548 is a fuser unit not installed error. But in combination with the Door Open indication, and the Chinese characters, I seriously doubt that it has anything to do with the fuser.
    I am not familiar with this particular model of Ricoh, but I would start with setting the destination (country/language setting). I don't really think that this will make any difference, even if you can access service mode. The most likely choice would be the I/O board or MCU board.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      possible PSU,for the door and sc code. sc 548 should be a fuser code. As for chinese showing up ..did this get zapped some how powerwise???? maybe NVram clear? The newer machines are doing more weird sH!t and firmware and NVram are a big part of it.
      Mystic Crystal Revelations
      • Zeldaman
        • Mar 2011
        • 946
