The copier (Aficio 6513) was working fine when the "Toner Low" message for magenta appeared. I ran a couple hundred more copies and then replaced the magenta toner.
After installing the new magenta toner, the copies were smudged and dirty a reddish color, which seemed like a lot of toner had been dumped. Once I cleaned out the bulk of the excess toner from the paper transfer, I was still noticing toner "scatter" on some of the copies.
And, I was getting a SC385 error after each print session (when the copier ran its self check) So, I cleaned out the toner revolver and re-installed all the toner cartridges and I pulled out the TD sensor, cleaned the whole assembly and replaced it. No more SC385 error, but still getting toner scatter and on top of that, now I'm getting "tire marks" on the bottom of every 8-1/2 x 11" sheet. (toward the front of the copier). One set of tire marks on each 8-1/2 x 11". They are about an inch long on the bottom of the 8-1/2 x 11, but I watched the image transfer belt during operation and noticed the marks on the belt and they extend beyond the end of the 8-1/2 x 11" (toward the front of the copier).
Are the "tire marks" and the toner scatter two different problems?
Did I mess something up when I cleaned or re-installed the TD sensor assembly? Or, is the drum (or the image transfer belt) not being cleaned off thoroughly during operation?
I would really appreciate any help or suggestions at all. Thanks for reading this. I know I got a little long-winded.
CK
CK
