If the drum unit is close to the PM cycle I would not just clean the charge roller. I'd also remove the drum and clean the blades, wax brush with a vac. If the drum surface looks healthy you might have a good chance to double the lifetime. The new charge rollers are unfortunately a step backwards - you can't really clean them with proper liquids. I just use water or glass cleaner for those.
Probably because they prefer to keep the lifetime close to the specified PM cycles^^ btw - larger diameters aren't automatically better. The MPC6000 PCU's are struggeling with the same issues.
In the end it is a design error from Ricoh. If they had increased the diameter of the charge roller and especially the cleaning roller, we would not have this problem. I don't understand why they used the foam roller either.
