Aficio 180 SC320
  • integritybob
    • Jul 2008
    • 67
    Aficio 180 SC320
    I have a Ricoh Aficio 180 that indicates SC320 when powered up. I have replaced the polygon motor (twice). Suggestions?
  • XXX
    • 69
    Check that none of the wires out back are rubbing on any motors and shorting the 24INT VDC.
    • Iommanxman
      • Aug 2009
      • 180
      Sometimes SC320 is not the polygon mirror motor but the actual laser itself. Try replacing the LD unit IF you can still get them...?
      • integritybob
        • Jul 2008
        • 67
        Hmm . . . I hadn't considered a power problem - I'll check it out. Thanks for the tip!
        • integritybob
          • Jul 2008
          • 67
          I don't have a source for the LD unit - parts for this model are getting hard to find, other than common PM parts. Thanks for the tip.
