RICOH MPC-2500
  • Polo-022
    • Sep 2007
    • 492
    RICOH MPC-2500
    I have a clunking noise from the fuser all the time...
    Because i have a little experience with this model, i would like to ask some help before any action!!
    I read TB's but didn't fine anything related...is this a known symptom?
    (60.000 clicks on the meter)
  • ejfh1
    • 16
    check drive gears for missing teeth,pressure roller for flat spots.
    • Eric1968
      • 2456
      Apply a little grease on the pressure roller bearings, that will solve it.
      • Polo-022
        • Sep 2007
        • 492
        Thanks a lot for your replies..., problem solved with "a little grease on pressure roll bearings'' as Eric1968 suggests...Greetings to Rotterdam!
        (By the way it is the same symptom as per 1022 series but in this case the noise was unbearable.)
        • Eric1968
          • 2456
          Yes, it's the same kind of problem. When I do maintenance on the fusing unit I always apply some grease on all bearings.
