MPC2500 Touch screen lose position
  • avandtos
    I m already setting touch screen adjustment save and exit is ok back to normal. And them i off the m/c and On the m/c steel touch screen lose foces problem. How to do it?
  • knightfall
    • Jul 2006
    • 633
    I would update the LCDC firmware and perform touchsreen adjustment the turn off the copier and on if it still same problem then replace the LCDC board.
    good luck
    Get your facts first, and then you can distort them as much as you please.
    • TonerMunkeh
      Professional Moron
      • 3865
      Replace the touch screen. It's a common fault on this model. B223 9900.
      Hit it.
      • teebee1234
        • 1670
        You need to replace the touchscreen, there is a known manufacturing defect that Ricoh is addressing by supplying updated ones to direct offices and dealers gratis. It's getting kinda late in the game to get them though, check your local office. Search the forums for this extensively queried subject (needs a sticky!).
        • TonerMunkeh
          Professional Moron
          • 3865
          But that'd just be easy, wouldn't it?
          Hit it.
          • mabawser
            Tech
            • Sep 2009
            • 121
            replace the touch screen as mentioned and your problem will dissapear. just finished doing one B223 9900.
            • foudl
              • Mar 2010
              • 138
              good luck
              How do you manage to do the touchscreen adjustment? .
              • zed255
                How'd ya manage that?
                • 1024
                Clear Modes, 1, 9, 9, 3, Clear Stop x5. Screen adjust is #1, touch with a pointy but not sharp instrument on the circles as prompted and exit.
                • foudl
                  • Mar 2010
                  • 138
                  I will also have to change the 4 drums on this machine (mpc 2500),do i have to clear any kind of counter(like sharp,since i'm a sharp tech) and if so ,how do you clear those counter?
                  Thanks in advance.
                  • ptrflrs
                    Glorified Parts Swapper
                    • Dec 2010
                    • 192
                    Thanks in advance.
                    reset copy sp 7804 and the pcu's u replace
                    jesus loves you! (everyone else thinks you're an assh*le)
                    street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
                    Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      No, if you just reset the PM counter the machine won't set up the new PCU's or developers. Go into SP3902, which is Manual New Unit Set. Tell the machine which parts you are replacing and it will initialise them when you turn it back on.
                      Hit it.
                      • rrowens
                        • Jan 2011
                        • 17
                        as said before replace panel ricoh updated them
