Cleaning charge roller on MPC machine
  • Ltd
    • 90
    I used some kind like formula K to clean charge roller on color machines ,It last the most 30K. Is there something better to clean will last longer ?
  • rsyarcia
    Hair Straightener Tech
    • 711
    we use water.
    Nobody is perfect..
    • mrwho
      Major Asshole!
      • 4299
      Water and soap.
      Mascan42
      Ibid
      • zed255
        How'd ya manage that?
        • 1024
        My favourite solution for cleaning these is a non-ammonia glass cleaner.
        • aabarnes1
          • Mar 2009
          • 620
          Spit,(saliva) believe it or not the enzymes in saliva clean charge rollers perfectly- DON'T let your customer see you though!
          Grant me the serenity to accept the things I cannot change.
          • alsi5
            • Sep 2010
            • 51
            I think water and soap are the better way
            • ezzysi
              • Oct 2008
              • 78
              Foam cleaner (we use the Parcia brand) brings them up like new, Then finish off with a quick wipe over with alcohol to remove any residue.
                • 23010
                As far as I can tell, it's just the nature of the beast. =^..^=
                • E Winter
                  I'm using scouring agent for the old type (black) charge rollers - it's a bit messy but has a nice polishing effect. The new type (brown) charge rollers are more delicate that's why I'm just using water or glass cleaner for those. I'm also removing the drum/cleaning unit so I can vac out the cleaning blades/wax brush.
                  • techspec
                    • Dec 2008
                    • 128
                    On the newer charge rollers( The Beige Ones) remove the beige coating with IPA to expose the white coating and you will get better life out the units.
