Ricoh Aficio 1018, drumunit.
  • Hansoon
    • Sep 2007
    • 3389
    Machine has 68K on the clock. Cleaning blade seems to be worn.
    What are you guys usually doing in this case. Changing the whole drumunit (nr. please) or only the drum + cleaning blade?
    Any other issues to take care of at 68K? UFR is fine.
    Hans
  • daveyball
    • May 2009
    • 314
    Hi
    The drum, drum blade, charge roller, charge roller cleaner all need chagned at 60K
    • TonerMunkeh
      Professional Moron
      • 3865
      Don't forget the developer too.
      Hit it.
      • zed255
        How'd ya manage that?
        • 1024
        I never rebuild these, new PCU assembly and developer. I know it costs more, but it's fast and I pretty much never have PCU related issues. I do however push them as far as they will go before replacing.
        • Hansoon
          • Sep 2007
          • 3389
          Thanks guys.
          part #'s please?
          Thanks!
          Hans
          • mikadonovan
            • May 2008
            • 2931
            Just replace these items, it's not difficult.
            Cleaning Blade B0392289, Drum B0399510, Charge Roller G0523510, Charge Roller Cleaner (Brush) G0602326, Developer Type 19 EDP Code 888095. If you absolutely have to replace the PCU as an assembly, the part # is B0392202
            NEVER ASSUME ANYTHING
            • tinnyjay
              • Oct 2009
              • 663
              Hans
              Without offends
              Where you find the nerves to work on Ricoh AF1018?
              I would suggest to drop it and to start usin medium workgroup machines.
              Ricoh AF1015-1018 needs a PM every 60k.
              Ciao
              "Who loves the roses,must also bear thumbs"
              • Hansoon
                • Sep 2007
                • 3389
                Thanks very much Gentlemen.
                In this economic depression one is happy with every new customer. Will not turn a customer down with an otherwise good working machine just out of bigotry.
                Hans
                • NEOTECH
                  • Dec 2010
                  • 69
                  change only consumable drum cleaing blade developer only and rest pm counter in mode 5.
                  • jonezy999
                    just one copy??
                    • Feb 2010
                    • 952
                    Re: Ricoh Aficio 1018, drumunit.
                    I'm with Zed on this one. Use complete units. The charge rollers setup in these makes it a nightmare to lube your drum/blade without contaminating the charge roller surface. Time is money.
                    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                    • Hansoon
                      • Sep 2007
                      • 3389
                      The post is 8 month's old but thanks anyway Jonezy...
                      Hans
