FX16 ''open heat error''?
  • avandtos
    • Aug 2025
    [Error Code] FX16 ''open heat error''?
    i on off same problem
  • teebee1234
    • Jul 2008
    • 1670
    Not sure what the fx16 is but the error relates to the fuser unit. It can only be reset through service mode once the problem is corrected. Most likely you will have to replace the fuser unit.
    • Jomama46
      • 2900
      Same as an AC104 which I think is an old Sammy unit. I think teebee is right tho.
      sigpic
      A+; Network +; PDI+
        • 23010
        I think you're right Jomama. The wording of the error points me towards a Samsung. I wonder why he posted in Ricoh? =^..^=
        • Eric1968
          • 2458
          The FX16 was sold by Ricoh as Aficio FX-16. We sold a couple of them, not much. It's indeed a Samsung. When he replaces the Fusing Unit the problem is solved. No need to reset the code.
