ricoh 1045: customer says if they run single copies no problem; if they try for 5 or more first copy will exit then paper stops inside fuser just before exiting copier. after clearing every copy stops at the same place. copier has over million copies with new feed tires and clutcheds. i did remove the bridge unit which appeared to be the problem but wasn't. thinking faulty exit sensor???
Thanks!!!
Thanks!!!
