aficio mpc3000 vs 4500 toner?
  • mrfuser
    • 1622
    Does anyone know if the toner is the same on the 3000 as the 4500, just different cartridge and chips?
    Kelly
  • TonerMunkeh
    Professional Moron
    • 3865
    With the developer being identical, you'd think the toner is too.
    Hit it.
    • Nortenio
      Unless there's a ricoh engineer who hangs out here, I think it'd be a hard question to answer. Which I'd be happily surprised to see actually.....
      • teebee1234
        • Jul 2008
        • 1670
        Since the developer is the same and comes premixed with toner in it, the conclusion should be then that the toner is identical. But not being privy to the component formula, I wouldn't go as far as saying it's unconditionally compatible.
        • KOPYTEK55
          • Nov 2009
          • 21
          MP C4500
          Gestetner Lanier Ricoh Savin
          Toner Black 888616 480-0393 888604 888612
          Toner Yellow 888617 480-0394 888605 888613
          Toner Magenta 888618 480-0395 888606 888614
          Toner Cyan 888619 480-0396 888607 888615
          MP C3000
          Item Yield Gestetner Lanier Ricoh Savin
          Cyan Toner 15k 888663 480-0379 888639 888659
          Magenta Toner 15k 888662 480-0380 888638 888658
          Yellow Toner 15k 888661 480-0381 888637 888657
          Black Toner 20k 888660 480-0378 888636 888656
          • cobiray
            Passing Duplication Xpert
            • Mar 2008
            • 1199
            I actually had our service manager ask our rep about this. He claimed there is a difference in the toner (I'm not buying it). Something about particle size with relation to the model. We did have an instance to use the incorrect toner in the machine and it did work. I think it was the 4500 in the 3000, but I could have it backwards. The one has a larger tab on the toner bottle (I think the 3000) which allows the other machine with the smaller tab to be used (I think 4500).
            • E Winter
              I'd bet that the toner is identical (on the chemical side) for both machines since the dev, pcu's and trasfer unit are identical as well. There's just different fuser but I think this is just due to the different process speeds.
              • Warren
                The toner is the same however the bottle voluum is different and could cause toner add problems due to the machines use gram count per bottle voluum to calculate when to add toner and whan to change toner bottle thus premature change of toner
                Ricoh also state that the toner particle has a different mircon size
                I have been a ricoh tech for 12 years in industry 22yrs
                Regards Warren
                • nick40
                  • Jan 2011
                  • 47
                  The toner is not the same. I remember reading something about some sort of lubricant added to the toner to eliminate the need of the oil roller in the fuser unit.
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    The MPC2000/2500/3000/3500/4500 all have an OSR. It's only the C2 and above that don't and they take different dev anyway.
                    Hit it.
                    • bategoiko
                      • Dec 2010
                      • 17
                      The toners are absolutely the same. Chemically, physically and so on...
                      Even the toner bottles are 100% identical.
                      You can use MPC3000 toner bottle instead of MPC4500. Even the RF chip is working. We tried that.
                      The only problem is that MPC3000 (15k yield) colour toner is almost the same price as MPC4500 colour toner (17k yield).
                      We didn't try to put an MPC4500 toner bottle directly on MPC2000/2500/3000 machine! It would fit, but I am sure RF chip would work.
