Ricoh Aficio 2105
  • tinnyjay
    • Oct 2009
    • 663
    Ricoh Aficio 2105
    Hello!
    I have a Ricoh Aficio 2105 and when copying from ADF in duplex mode,one side is ok,other side is cutted.
    I tried SP6009,but it doesnt work.I checked the values in Service Mode and they are default.
    All i could do is a cleaning and i did it.
    What can i do please?
    Thank you
    PS : Copying in Duplex Mode on glass,is perfect.Also the printing.
    "Who loves the roses,must also bear thumbs"
  • rthonpm
    • Aug 2007
    • 2859
    Make sure there isn't a margin set for the duplex in User Tools. This will give you all kinds of grief if you don't know to look for it.
    • tinnyjay
      • Oct 2009
      • 663
      Maybe i didn't explain as good as the problem really is.
      It is not problem of margins,but the image in the copy,is pulled down.
      In one side copying is ok and in other side,the image is moved down to the edge of paper and maybe 1 or 2 lines (sentences) are missing or cutted.
      I made a SP5801 and SP2962 and the problem is still present.
      • jonezy999
        just one copy??
        • Feb 2010
        • 952
        Post an example.
        Check duplex margin in user tool like rthonpm mentioned. They are set to shift the image 5mm on the 2nd side from factory. Change it to 0mm and the back will be the same as the front.
        I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
        • tinnyjay
          • Oct 2009
          • 663
          Originally posted by jonezy999
          Post an example.
          Thank you
          Solved
          It was a problem of Motor 2 in duplex.
          • jonezy999
            just one copy??
            • Feb 2010
            • 952
            Originally posted by tinnyjay
            Thank you
            Solved
            Good to see a solution. Nice find.
