ricoh mp 2550 hard drive
  • yannii33
    • 121
    What kind of hard disk goes in to a mp2550 and is there a part number
  • ricoco
    • Jan 2011
    • 122
    Originally posted by yannii33
    what kind of hard disk goes in to a mp2550 and is there a part number
    thanks
    m3085130 - hdd:80gb:mhz2080bh:fujitsu
    • anothertech
      • 1766
      If you have an adapter to hook it up to your laptop, you can usually reformat the drive and it will be as good as new. Works about 9 out of 10 times.
      • jonhiker
        • 661
        i agree with anotertech. however, an off the shelf hard drive will work just fine vs ordering one from Ricoh. $$$$
        it is a laptop hdd and i think it is SATA. i usually pull the drive and look.
        • ricoco
          • Jan 2011
          • 122
          Yes. It is SATA
          • yannii33
            • 121
            Can it be formated in the machine from the machine or do I need a laptop and windowa thanks
            • ptrflrs
              Glorified Parts Swapper
              • Dec 2010
              • 192
              agreed. i usually do a low level format to be sure but i think its a MBR file corruption i have also been able to use any generic sata drive
              jesus loves you! (everyone else thinks you're an assh*le)
              street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
              Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
              • ptrflrs
                • Dec 2010
                • 192
                i dont think u will be able to format with the error code but if u look on ebay u can find a cheap sata to usb adapter for ur lappy. u will also lose your address book entries...
                u can format drive in windows or linux
