Problem copy on the glass
  • sebreizh
    • Oct 2009
    • 28
    Hello,
    I have a problem with a copier IS2320/MP2000. I want to copy an A4 sheet by the DF it out in A4. I want to copy an A4 sheet on the glass, it comes out in A3. Can you tell me?
    Thank you.
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Is the printed image enlarged or rotated?
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • rsyarcia
      Hair Straightener Tech
      • 711
      check the sensor, maybe it is not detecting the adf when even it is closed
      Nobody is perfect..
      • sharpmind
        • Sep 2009
        • 478
        Check the original size sensor perhaps it is dirty.Clean it and see the results.
        • sebreizh
          • Oct 2009
          • 28
          I already changed the format sensors under the glass.
          Always the problem.
          The image is normal no enlarge A4 to A3 on a left side.
          • zed255
            How'd ya manage that?
            • 1025
            ADF position sensor. When you close the lid the APS is seeing the white platen cover and selecting A3.
            • g.morello
              Re: Problem copy on the glass Not detecting right size
              We checked optical sensors and were ok, then we checked and cleaned CCD sensor (that's because one size is checked by CCD sensor before scanning the document) and the problem seemed to be solved. But after a few hours the problem come back.
              Any other clue to solve this.
              Thanks for your help.
              Giuseppe
              • teebee1234
                • Jul 2008
                • 1670
                You still didn't say whether or not you checked the APS set sensor per ZEDs post. The actuator (spring loaded) is attached to the right hinge of the ADF (drops thru a cutout in the bottom) and engages the photo interuppter on top of the scanner. If the actuator misses or is hung up, the set sensor won't "tell" the size sensors under the glass to take a snapshot of the paper as the lid is closed and thus detects the entire platen as the size (A3).
                • Polo-022
                  • Sep 2007
                  • 480
                  It is a Platen Cover Sensor problem (the left one!!!). In your case it acts like an "adf home position" sensor and it is mounted on the copier not on ADF!
                  Check through diagnostics SP-4301 and clean or replace with the exact part number
                  • g.morello
                    we checked both APS set sensor and Platen Cover Sensor. They were the first sensors checked. They actually works.
                    The weird think is that afer a cleaning of the CCD the machine was woring fine for almost 2 hours.
                    • g.morello
                      We are sorry we misunderstood about this post.
                      We were talking about MPC2050 and MPC2800.
                      I was wrong in reading the first post of this 3ad.
                      If you can help us too would be apreciated.
                      Thanks.
