I was working on D555 machine and it was throwing an error intermittently.I checked the scanner unit and fixed it properly.The movement of the scanner unit was ok and no skew.It would work for sometime and suddenly error came.I had tried to replace the scanner motor but still an error showed again. When you shut the machine down and power on again, the error gone. I cleaned the controller board as dust accumulated on it. After doing this stuff, the machine was running fine.I tested the machine many times and it was ok. I left the machine working but I was not convinced I had done it. I was thinking that error would occur again.
Another error occurred in the machine and that was SC 345. Can you tell what was the cause of all these errors?
Thanks!
Thanks!
