Ricoh MP C4000 NO POWER!
  • jonbonse
    • Jun 2009
    • 737
    I went to a Ricoh MP C4000 with no power today but could not get it going again.
    On the power supply, fuse FU1 (8a 250v) was blown so I replaced with the same but it blew it out again!
    In these cases I would normally replace the PSU but uncertain that it would be a good move as I have no circuit diagram for this machine.
    I have the SM but cannot see the circuit diagram.
    The customer tells me it is less than a year old so was wondering if this would be covered via Ricoh waranty?
    Any advise on this kind of fault finding is appreciated.
    John
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    The factory warranty is 90 days, at least last I knew.
    • tcs04
      FORMER Techie
      • 1183
      We did have an mp4500 blowning fuses due to a short in the wiring inside the right hand door.
      • Eric1968
        • 2458
        I would remove all connectors from the PSU and check if the fuse still blows. If it doesn't blow the PSU should be OK.
        • TonerMunkeh
          Professional Moron
          • 3865
          Change the PSU and the IH coil PSU as a pair. I've had a few do this and this, unfortunately, is the final fix.
          Hit it.
          • jonbonse
            • Jun 2009
            • 737
            Thanks TonerMunkeh
            Do you have part numbers for these?
            The PSU and the IH PSU? What about the IH Coil?
            • TonerMunkeh
              Professional Moron
              • 3865
              AZ24 0136 for the main PSU and the coil PSU is D029 5172. I've never had to change the coil itself.
              Hit it.
              • jonbonse
                • Jun 2009
                • 737
                Thanks!
                Is this also known as the IH Inverter?
                • jonbonse
                  • Jun 2009
                  • 737
                  Hi
                  Just an update:
                  I returned to investigate further and performed the following:
                  Unplugged all connectors on the PSU at the bottom rear of the copier and switched on. The fuse did not blow.
                  U plugged in all connectors one at a time and turning on after eCh one.
                  The fuse FU1 on the main PSU did not blow until I plugged in the cable which goes to the IH PCB.
                  I then unplugged it an switched on again and it powered up.
                  I then switched off and unplugged the black connector cn982 on the IH, powered up and it was ok.
                  The copier will blow FU1 on the main PSU only when this is connected...
                  I can't find any shorted wires any where even in the Fuser.
                  My guess is that the IH coil is shorting out somewhere?
                  I think the main PSU is ok?
                  What do you think?
                  • brodera
                    • Aug 2009
                    • 106
                    Originally posted by jonbonse
                    Hi
                    Just an update:
                    What do you think?
                    This has hapend to me recently. Check the for *What do you call these* "Electrical spikes" '
                    You can try after the fuse-change plugg the powercontact in to a separate PSU Station..
                    • jonbonse
                      • Jun 2009
                      • 737
                      TonerMunkeh
                      I hear there is a Tech Bulletin for this kind of fault (RTB 029051 ). .. . . . I dont suppose you have it so I could take a look?
                      Also I hear you have to replace the Main PSU, IH Inverter and IH Coil to completely cure this fault?. . . . .
                      My manual doesn't list the IH Coil so was hoping you could give that too?
                      Thanks for all your help!
                      • teebee1234
                        • Jul 2008
                        • 1670
                        RTB No.: RD029051 :
                        IH invertor improvement
                        Details<Symptom>
                        Fuse on PSU can brow out at the following timing.
                        - Main switch ON
                        - Front door or duplex unit close
                        Answer
                        Old part number D0295172
                        New part number D0295173
                        Change
                        A capacitor on IH invertor has been changed.
                        Reason
                        The following issue can occur.
                        <Symptom>
                        - Main switch ON
                        <Cause>
                        A broken element device on IH invertor.
                        Temporary blackout can cause over voltage. As the result, it causes the element to break.
                        <Solution>
                        Action required at the field
                        Change IH invertor.
                        • mabawser
                          Tech
                          • Sep 2009
                          • 121
                          Had the IH inverter board cause this to blow on numerous occasions, fit a new fuse to the power supply and order up the inverter board and fit this and you should be ok.
