MPC 4000 df jams A4r only
  • GC-SCO
    • 26
    Hi there, Im looking for some input into a wierd fault. I have an MPC 4000 which will run A4r and A3 all day long but will struggle to get through a pile of 20 A4r on the DF. It shows 005 DF jam (exit Jam). I have cleaned all sensors and rollers but it still ajms intermitantly.
    Any help appreciated.
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    What model DF?
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • GC-SCO
      • 26
      its a DF3010...
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Did you clean the non reflectors on the bottom of the DF? There is one on a metal plate just to the left (before) the slit glass. There is another one on the right (after) the slit glass on the black plastic guide.
        • GC-SCO
          • 26
          I have cleaned all sensors and no reflective plates. I have also cleaned all rollers as well as replacing feed belt,roller and dfp.
          All other sizes A3 - A4 work fine. It jams solely on A4 r.
          • cobiray
            • Mar 2008
            • 1199
            There's also a TSB regarding ADF jams that came out last year sometime. There was some damage to the original white plate that caused it, but I haven't seen it in the field.
            • ucinn
              • Jun 2009
              • 383
              There's a one way on the I believe registration roller, clean and lube and buff the shaft.
              • jonezy999
                just one copy??
                • Feb 2010
                • 952
                I had a similar issue which I struggled with for a while, I did everything you did. Ended up replacing the original feeler bracket and problem solved. Don't know why but tech support were straight onto it.
