MPC 4000 df jams A4r only
  • jonezy999
    replied
    I had a similar issue which I struggled with for a while, I did everything you did. Ended up replacing the original feeler bracket and problem solved. Don't know why but tech support were straight onto it.
  • ucinn
    replied
    There's a one way on the I believe registration roller, clean and lube and buff the shaft.
  • cobiray
    replied
    There's also a TSB regarding ADF jams that came out last year sometime. There was some damage to the original white plate that caused it, but I haven't seen it in the field.
  • GC-SCO
    replied
    I have cleaned all sensors and no reflective plates. I have also cleaned all rollers as well as replacing feed belt,roller and dfp.
    All other sizes A3 - A4 work fine. It jams solely on A4 r.
  • cobiray
    replied
    Did you clean the non reflectors on the bottom of the DF? There is one on a metal plate just to the left (before) the slit glass. There is another one on the right (after) the slit glass on the black plastic guide.
  • GC-SCO
    replied
    its a DF3010...
  • jonezy999
    replied
    What model DF?
  • GC-SCO
    started a topic MPC 4000 df jams A4r only
    Hi there, Im looking for some input into a wierd fault. I have an MPC 4000 which will run A4r and A3 all day long but will struggle to get through a pile of 20 A4r on the DF. It shows 005 DF jam (exit Jam). I have cleaned all sensors and rollers but it still ajms intermitantly.
    Any help appreciated.
