multiple sheet feed thru document feeder on a 201 ricoh
  • bayrat
    • Aug 2025
    [Jamming] multiple sheet feed thru document feeder on a 201 ricoh
    Has anyone had any problems with multiple sheet feeding thru the df on the new 201 ricohs
    probably the same feeder as the 171 even new out of the box?
  • Jomama46
    • 2900
    This was addressed with the 161. They changed the spring that applies pressure to the sep roller. It lessened the pressure. I would try to reform it just a little to see if there is an improvement.
    sigpic
    A+; Network +; PDI+
    • bayrat
      Thanks that seems to be the only option. That is to try and reform the spring and check the results.
