Using a SP820D fuser in a C5000
  • Jomama46
    • 2900
    I have to install a fuser in a C4000 and I have the 820D printer fuser and want to mod it. The info in a different thread says the pinouts are the same as the c4500 but they arn't. Has anybody tried this yet.
    Here is a pix of the printer fuser
    sigpic
    A+; Network +; PDI+
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    sigpicWe can all Win, but at the end we all loose. Save the greyhound
    • Jomama46
      • 2900
      what I was saying was the thread was that the mpc4500 and the mpc 4000 fuser was the same. Not. I have donr a few of the C4500 conversions. As you can see from the pix they arnt the same
      sigpic
      A+; Network +; PDI+
      • iMind
        • Mar 2008
        • 1116
        • iMind
          • Mar 2008
          • 1116
          • Jomama46
            • 2900
            Well you are right, iMind, they look the same. But if you compare the P2P to the pix I posted, that cotton-pickin' blue jumper is not on pins 1 and 2 as is indicated on the P2P. Maybe the US versions and the EU versions are different. There is a tech out there now with the fuser and he will physically check the jumper position.
            sigpic
            A+; Network +; PDI+
            • Jomama46
              • 2900
              I was assuming that the blue wire jumper was the new detection, but it isnt, it is the fusing area setting. Pins 4 and 6 are for US. New detection must be two black wires. Maybe no changes at all for printer to copier?
              sigpic
              A+; Network +; PDI+
              • iMind
                • Mar 2008
                • 1116
                Yep, I had a look and I think there are three region fuser settings TW:EU:NA that may have to do with the jumper "CN" positioning
                • Jomama46
                  • 2900
                  Here is the answer. You will notice that the left blue wire (destination) is moved one pin to the left, leaving 2 not 1 space between the wire. Not shown in either schematic.
                  Uploaded with ImageShack.us
                  sigpic
                  A+; Network +; PDI+
                  • iMind
                    • Mar 2008
                    • 1116
                    Thats true, Thanks, aways learning, good work.
                    • Jomama46
                      • 2900
                      Thanx, I try to contribute all I can
                      sigpic
                      A+; Network +; PDI+
                      • AyJayAreDii
                        • Jul 2010
                        • 99
                        If in doubt swap the entire wiring, no need to guess which wires to swap then.
                        Has anyone worked which printer the MPC5501 would be the same as?
                        • iMind
                          • Mar 2008
                          • 1116
                          . ...said by the collector
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            Re: Using a SP820D fuser in a C5000
                            ::EU Fuser (Aust) ::
                            SPC820 printer fuser into MPC copier conversion.
                            Move pin 1 into pin 2 slot.
                            Disconnect the counter reset fuse. (Its not required.)
                            Reset the fuser counter manually in service mode.
                            You guys already knew that any way....
                            • kannuki2
                              • Feb 2012
                              • 398
                              Does this apply to the North America fuser also?
