Lines on Savin 7025 on 2 units!
  • xxmandingoxx
    • Jun 2011
    • 61
    [CQ] Lines on Savin 7025 on 2 units!
    [Lines]
    Allright, i have 2 units out in the field currently with lines only on copies.... printing is fine i get absolutely no lines...
    Ive cleaned everything i can possibly think of mirrors / glass etc etc, also the one behind the drum unit i cleaned and the line is still there...
    It is stationary and always in the same spot ive tried matching it up with various parts of the unit with no avail, i dont even know what to replace at this point, would definitely appreciate an assist!
    -Thanks in advance
    -Mike
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Is it the same from the glass and the doc feeder? Have you cleaned off the lens? Is it a blurry line or a well defined line? Scans of the image would help too.
    • xxmandingoxx
      • Jun 2011
      • 61
      i haven't cleaned the lens yet actually it didnt occur to me, must of had tunnel vision
      but it is well defined and the same exact line from doc to glass
      just seemed odd cause it happened to 2 machines within 2 weeks of each other and im just scratching my head
      • cobiray
        • Mar 2008
        • 1199
        Also don't forget the white sheet, reflector and the lamp itself.
        • xxmandingoxx
          • Jun 2011
          • 61
          allright ill check it out, and thanks!
