Mpc 4000 fuser connector ( copier side)
  • eric
    • Oct 2010
    • 25
    HELLO
    l'm go in research of the reference of fuser connector(copier side)i have not found it in the parts catalogue
    it's the connector with the AC wire,some one know the reference?
    thanks
  • Jomama46
    • 2900
    Re: Mpc 4000 fuser connector ( copier side)
    Try the Point to Point diagram.
    sigpic
    A+; Network +; PDI+
    • eric
      • Oct 2010
      • 25
      l've tryed but it's only one not refer
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        There's RTB 68 but I'm not sure it is referring to the fuser connector on the main machine.
        Change/Reason: The following parts (Drawer connector and harness ass’y)
        were missing from the parts catalog, and P to P
        D0294152 HARNESS:FUSING UNIT:NA
        D0294153 HARNESS:FUSING UNIT:EU
        • eric
          • Oct 2010
          • 25
          thanks
          yes, l research these connector but for the other side (inside the copier)
          l thing l'm not alone with this connector broken ??
          • eric
            • Oct 2010
            • 25
            better than of the explanations,an image.
            • eric
              • Oct 2010
              • 25
              Re: Mpc 4000 fuser connector ( copier side)-CLOSED
              hello
              l've found!
              for Your information the ref is D029 5334
              • Jomama46
                • 2900
                Good job eric, thanks for persevering and sharing the info.
                sigpic
                A+; Network +; PDI+
