hi guys i just got a jamming problem its J014. the paper was stock after the fuser unit inside the exit conveyance, before the exit sensor. i had replaced the top roller and the claws but still J014 appears please really need, help thanks guys.
Jamming Code J014
Re: Jamming Code J014
On what model of machine?!?!It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
You replaced the pressure roller? Does this happen on double or single sided? First copy of the day or all the time? Checked the sticky pads in the interchange? Exit sensor? Duplex entrance sensor?It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
You replaced the pressure roller? Does this happen on double or single sided? First copy of the day or all the time? Checked the sticky pads in the interchange? Exit sensor? Duplex entrance sensor?Comment
Pull the scanner off the machine and remove the exit section. (2 scews, I think, and a couple of connectors). The solenoids have cushions on them to reduce noise. These cushions get hot and the adhesive melts causing the solenoids to stick.NEVER ASSUME ANYTHINGComment
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
Paul@justmanuals.com
guys, i pulled out the unit and bought it to our shop, i had removed the scanner and copied and found that the jammed paper is upon reaching the exit sensor and the solenoids are fine they don't stick, the paper stops upon reaching the exit sensor and i replaced the exit sensor but to no avail. guys do you have any ideas on where or what is the problem of this machine? is there a wiring diagram available for this machine Ricoh aficio 2035? maybe the point to point wiring diagram would help me solve this problem.Comment
