2035 esp 545 error
  • Tonernick
    • Jul 2025
    2035 esp 545 error
    Hi,
    I am servicing a ricoh 2035 esp with intermittent sc 545 codes for approx 3 weeks. I have had 3 different fuser units, 2 different I/o boards, cleaned and inspected fuser connect, checked all temp. settings but still getting the 545 code. suggestions?? Thanks
  • dawn
    • Mar 2011
    • 48
    Re: 2035 esp 545 error
    Try to replace dc power supply board.
    • Tonernick
      Whoops ....forgot to mention that we did replace the power supply..Thanks
      • rthonpm
        • Aug 2007
        • 2859
        Check your voltage from the wall, and your firmware levels.
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
          Paul@justmanuals.com
          • sandmanmac
            • 3981
            I agree, maybe try another circuit if available, and surge suppressor
            • BLADE
              former propeller tester
              • 478
              you could try replacing the two sets of door switches or swapping the front door switches with the fuser door switches
              • ESTANISLAOWENENTON
                POWER SUPPLY
                • lupi
                  • Aug 2011
                  • 102
                  yuor solution 100% to
                  SC545 Heating roller fusing lamp consecutive full power 1
                  Replace the heating roller thermistor
                  okay
                  • xordi69
                    • Jun 2010
                    • 200
                    BLADE is right...door switches
