Hello all,
I have a Savin 4075 with what seems to be a fusing problem.
Using standard 20lb paper, copies are coming out with toner streaks from the fusing unit. Causing the machine to jam before the paper reaches the fusing unit, you see that the image looks fine with no streaks. The streaks seem to start at the lead edge. The customer also prints on a thicker letterhead paper and the problem is much worse on that paper. Looks like very poor fusing. You can even wipe off some of the image from the letterhead paper.
I've made sure all the fusing SP settings are at default.
I've replaced: Upper and Lower fusing rollers. Upper and lower fuser roller bearings. Upper roller bushings, both thermistors, fusing web and web pressure roller.
After replacing all that, my symptoms were worse than when I started.
I did get a little better results when I increased the fusing temp in SP settings. I think the normal setting is 190F and I maxed it at 205F. But the problem remains.
My manager suggested replacing developer to see if there is defective toner causing the problem.
Any other suggestions would be welcome.
