aF3245C - A3 COLOUR PRINT ISSUE
  • bcoulson
    • Mar 2009
    • 10
    [CQ] aF3245C - A3 COLOUR PRINT ISSUE
    I am having an issue with a Af3245c, A4 colour correct and test ok, black a4 + a3 great, colour a3 prints/copys halfway through image transfer - noise can be heard like slipping belt, causing colour registration issue, new transfer belt installed. new cleaning transfer unit installed. same problem - any ideas please
  • Jomama46
    • 2900
    Re: aF3245C - A3 COLOUR PRINT ISSUE
    Did you clean the rollers that drive the belt, before installing the new one?
    sigpic
    A+; Network +; PDI+
    • bcoulson
      • Mar 2009
      • 10
      yes the transfer unit rollers are shiny clean, so its not registration, as auto colour registration is ok, its only a3 colour printing, not a4 colour or a3 black, seems strange, like a loading issue.
      • jonezy999
        just one copy??
        • Feb 2010
        • 952
        Have you tried fresh paper? I've seen these machines have copy quality issues only on A3 turn out to be damp paper. Didn't have any noises like you say though.
        I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
          • 23007
          Along these same lines, what about media type? Is this A3 paper also heavier stock, and are you using the correct media type settings? =^..^=
          • Hadster
            • Aug 2011
            • 264
            Interlock the door open and press on the transfer cleaner blade lever to see if the noise goes away. If so, not enough lube (toner) on the new transfer blade.
            • JustManuals
              • Jan 2006
              • 9838
              This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
              Paul@justmanuals.com
              • Herrmann
                • Jan 2006
                • 792
                Had exactly this Problem 3 Years ago, never found a Solution to this
                The Mashine took its Secret down to its Grave
                If someone has a Solution to this, let me know, i still want to learn
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
