mpc 3000 copy quality issues
  • johnny32
    • Oct 2007
    • 102
    I have a mpc300 mfp which is giving me copy quality issues only from the glass and adf.See the attached image. I have chaned the lens block ass and also the lamp but to no avail. Any help would br greatly appprieciated . The problem only occurs in copy mode and not when printing
    20110822170400240.pdf
  • Herrmann
    • Jan 2006
    • 792
    Re: mpc 3000 copy quality issues
    Grab the front left Edge of the Scanner Frame and pull it upwards, then make a copy again while pulling. What happens?
    Did you perform the ATR Adjustment?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • rjfellizar2468
      [ATTACH]11409[/ATTACH]
      Mr. Johnny I see some lines on your copy, please verify if your slit glass is clear from any scratches. You can adjust density of document feeder in service mode. If all of this fails you can replace slit glass and lamp, by the way the amount of copies is quite high.
      • sandmanmac
        • 3979
        The post states clearly that it happens on the exposure glass as well, and the # of copies means nothing.
        Have you tried doing the auto colour calibration for copier? You say you have replaced lens block and lamp, but have you also thoroughly cleaned all the mirrors and reflectors in the optics section too?
        • Fearless V K
          • 620
          Just looks like some dust on the scanner mirrors to me. see that all the time. you said you cleaned the lamp and lens block but did you clean the mirrors?
          Don't take that toner with me!
          • johnny32
            • Oct 2007
            • 102
            All the mirrors have be throughly cleaned and there is a complet backround on the copies.Was wondering if anyone has had to adjust the postion of the scanner as suggested in the the first reply. All colour calibrations done and print outs fine.
            • Iowatech
              Not a service manager
              • 3930
              Might check scanner "Manual Gamma" (4-918), default value is 15. I've had to play around with that (and on the older machines that would bite me in the sitting muscle every so often). Still, larger values make darker copies (from the platen glass as well as the document feeder) and has no effect on printed images.
              • Ianizer
                • Jul 2011
                • 380
                Okay wait.
                Are we talking about that nasty optical distortion, or the spots?
                Could it be related to that bad run of CCDs Ricoh has awhile back?...
                -I
                My name Peggy.
                You got problem?
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  I've had a dirty white reference plate cause mental problems like this on an Athena. It wasn't actually VISIBLY dirty, just a layer of of muck on there the machine could see but I couldn't.
                  Hit it.
                  • MobileTechy
                    did you clean the drum mirror .. the mirrors above the drum if any .. normally on right side of copiers
                    • 1nevster
                      • Dec 2010
                      • 49
                      O Dear
                      • johnny32
                        • Oct 2007
                        • 102
                        Hi just an update
                        The problem has been solved
                        The setting in the sp modes for sp4 265 were way out of whack.Dont know why but at least it solved
                        Thanks for the responses
