MPC6000 has error SC 672
  • sostek
    • May 2010
    • 80
    [Error Code] MPC6000 has error SC 672
    Hello all, I tried to look the code up, but it's not there. other models point to the controller or op panel. Any suggestions?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MPC6000 has error SC 672
    There's a few firmware updates for this SC, might be a good place to start.
    Hit it.
    • Moza
      • 232
      SC 672 is usually memory dimm's
      • trottinbob
        672 is controller start up error. Start with basics. Try booting from firmware card and install "latest & greatest" if possible (see below) . If not working. Disconnect the Hard drive and try to reboot . If not working pull the fax board out and try again. Reseat memory dimm's try again . If still failing. Try booting without the Print/Scan sd card.
        If this is older unit the firmware was a known fix . Had sleep issues (STR) when on network.
        System 1.08 or newer along with Web Support 1.08 or newer and NCS 7.11 or newer.
